1993 Oldsmobile Cutlass No combustion on starting
ARABICAA
  • 1993 OLDSMOBILE CUTLASS
Engine Performance problem
1993 Oldsmobile Cutlass Two Wheel Drive Automatic
The car wont start without adding starting fluid to the engine and then it wont stay started. What could be the problem?
Saturday, March 20th, 2010 AT 10:56 AM
JDL
  • 16,098 POSTS
Hi, how long since a tune-up? Use a gage and check fuel pressure. Possible issue with fuel pump or wiring circuits. If the pump doesn't run, check proper terminals at fuel pump connector for voltage and ground. When you first turn the key on, no crank, can you hear the pump run?
Saturday, March 20th, 2010 AT 11:13 AM
ARABICAA
It has been sitting for about two years without any kind of maintenance.
Saturday, March 20th, 2010 AT 11:42 AM
