On some models you will need to remove the headlight bezel mounting screws and the bezel.
Remove the mounting screws for the lamp assembly.
![https://www.2carpros.com/forum/automotive_pictures/261618_0900c152800cc71d_1.jpg](https://www.2carpros.com/forum/automotive_pictures/261618_0900c152800cc71d_1.jpg)
After the screws are removed, pull the assembly from the vehicle.
Disconnect the twist lock socket from the lens housing.
To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise1/4turn, then remove the socket with the bulb; replace the bulb if defective.
To install:
Install the electrical harness to the back of the unit.
Position the signal assembly, then attach to the vehicle with the mounting screws. Tighten the screws to 54 inch lbs. (6 Nm).
Insert the socket to the back of the unit, then attach the headlamp bezel if removed.
SPONSORED LINKS
Tuesday, March 2nd, 2010 AT 4:14 PM
