1995 Oldsmobile Cutlass
TBOMBDRUMS
  • 1995 OLDSMOBILE CUTLASS
Electrical problem
1995 Oldsmobile Cutlass 150000 miles
I just put a new turn signal switch in and everything works, but when I use my turn signals the brake lights go off. What is the problem?
Saturday, February 23rd, 2008 AT 5:10 PM
BMRFIXIT
  • 19,053 POSTS
What was the problem before?
Check the light bulbs
when you have the signal on
none of the brake light go on when stepped on brakes
let me know
Saturday, February 23rd, 2008 AT 5:34 PM
BMRFIXIT
  • 19,053 POSTS
To: BMRFIXIT
Posted: Sun Feb 24, 2008 11:52 am
can you let me know why did you replace the switch
and if that problem was on going from before (replacement of the switch )
also may I suggest checking the ground
make sure u used the correct part #
check with the part store you used make sure u provide them will all the options on the car
Sunday, February 24th, 2008 AT 11:08 AM
