1991 Oldsmobile Cutlass Air in brakelines, where's it comin
1991 OLDSMOBILE CUTLASS
77,000 MILES • 6 CYL • FWD • AUTOMATIC
MANGUMMIKE
Hi, I've been getting air in my brake lines, mostly near my passenger rear caliper, and there does not appear to be any fluid leak. Reservoir level fluctuates with application of brakes but no change in overall level. I've replaced the brake master cylider about a month ago and rotors and pads all-around four months ago. Did not see anything to raise concern then. I do get engine speed fluctuation with the application of the brakes. May be a vacuum leak to the power booster. Any ideas? Could a potential vacuum leak cause air to get into my brake system, or is it likely a bad caliper? Thanks
Feb 27, 2009 at 8:05 AM
MERLIN2021
  • 17,250 POSTS
Likely a caliper remove it and pull the dust boot back to inspect it, some assembly fluid is OK, but a heavy amount of wetness isnt! If they check out OK pull the master away from the booster, is it dry in between? Now as for the speed change, the plastic piece the vacuum hose goes to is the check valve, take it of, and try sucking thru both ends, air should only pass one way. Replace it if you can suck air thru both ends.
Feb 27, 2009 at 8:10 AM
