1991 Oldsmobile Cutlass Engine stalls when slowing down
RUSTYRAT
  • 1991 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 150,000 MILES
91 Olds Cutlass Supreme (3.1 L, 6 cyl.) Stalls when slowing down. Will not restart until after some amount of time like overnight.
Friday, April 16th, 2010 AT 2:09 PM
Next time it will not start do below to find out if its a fuel or spark problem don't wait for nothing
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, April 16th, 2010 AT 2:17 PM
