Engine Performance problem
1988 Oldsmobile Cutlass 6 cyl Front Wheel Drive
cranks but wont start unless i spray starting fluid in the air intake the car is a 2.8 liter multi port injection and im getting spark and good fuel psi but when i take off the connector at the injector im getting power to both terminals on the harness i read that only one side should get constant power and the other should pulse when the engine is cranking
Aug 23, 2009 at 2:20 PM
