1987 Oldsmobile Cutlass Random cutting off
1987 OLDSMOBILE CUTLASS
174,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTIN4APPLE
I have an 87 Cutlass Ciera Brougham. 2.8l
Car has been running great untill today. it will run ad the die like its out of gas. if i wait for 10 min or so it will start and run again for another 10-15 min. then the same thing happens again.
Herd maby the ignition coil, or maby the fuel pump. is there a way to test if its the fuel system or the ignition system.
Jun 30, 2010 at 6:14 PM
  • 110,244 POSTS
It sounds like a bad ignition module. However, here are "How To's" for checking fuel pump pressure and the ignition system:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Let me know what you find.
Jul 1, 2010 at 6:28 AM
