HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Cutlass
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1992 Oldsmobile Cutlass
BILLYT88
MEMBER
1992 OLDSMOBILE CUTLASS
Engine Performance problem
1992 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
it studders when I slow down like it isnt getting gas. Sometime it stals.I changed the fuel pump and the filter hat else could it be.
Tuesday, March 9th, 2010 AT 9:07 AM
BILLYT88
MEMBER
SPONSORED LINKS
Tuesday, March 9th, 2010 AT 9:08 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1993 Oldsmobile Cutlass Fuel
I Have A 1993 Olds Cutlass Ciera S And I Had A Problem With It Stalling. It Happened Once And Then The Car Started Again Fine. A Few Weeks...
Asked by
obrien1987
1 ANSWER
1993
OLDSMOBILE CUTLASS
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
Fuel Trouble
The Car Quit Running, I Had It Towed To Shop They Changed Fuel Pump And Filter. It Still Does Not Run. I Checked The Fuse Relay. It Gets...
Asked by
Wildman12
1 ANSWER
1993
OLDSMOBILE CUTLASS
Fuel Pump
How Do You Replace A Fuel Pump On A 1993 Cutlass Cierra
Asked by
charlesrentz
1 IMAGE
1993
OLDSMOBILE CUTLASS
1991 Oldsmobile Cutlass Fuel Pump Hummmmmmm
My Mechanic Has Replaced The Fuel Pump Because Of An Awful Hum. I Still Have The Hum. It Is Very Annoying. Have You A Solution To The...
Asked by
sockos94
1 ANSWER
1991
OLDSMOBILE CUTLASS
1993 Oldsmobile Cutlass Fuel System Problem
Engine Performance Problem 1993 Oldsmobile Cutlass 6 Cyl Front Wheel Drive Automatic I Just Put A New Fuel Pump On My 93 Olds Cutless...
Asked by
bearman2733
1 ANSWER
1993
OLDSMOBILE CUTLASS
VIEW MORE
SPONSORED LINKS
Fuel Pump Pressure Test
How to fix an engine that wont start
Engine Not Starting
Online car repair manuals
