1986 Oldsmobile Cutlass
SOCCERBRADMAN
  • 1986 OLDSMOBILE CUTLASS
1986 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
Ill try to start it and the fan will run, their will be a faint clicking but nothing will turn over
Saturday, April 17th, 2010 AT 10:29 AM
Pick your symptom:
**Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Sunday, April 25th, 2010 AT 5:07 AM
Related Engine Not Running Content
