1994 Oldsmobile Ciera fuel pump fuse location
KING GEO
Electrical problem
1994 Oldsmobile Ciera 141409 miles
my fuel pump went out on me a couple of days ago . i replaced my fuel pump & fuel pump relay but i can't find the location of the fuel pump fuse .
Aug 31, 2009 at 6:13 AM
JDL
  • 16,098 POSTS
it should be under the hood, passenger side front, around the relay pack, 15 amp. There is also a fuel pump prime connector in the general area, that is a test connector for the pump. You can run the pump without using the key. Red wire with electrical connector, nothing plugged into it, If you use a jumper wire from battery+ to the connector the pump should run, use an inline fuse, if you try it. Some databases give different locations for that connector.
Aug 31, 2009 at 6:52 AM
