1988 Oldsmobile Ciera engine not starting
IMADKNIO
  • 1988 OLDSMOBILE CIERA
  • 6 CYL
  • FWD
  • 71,000 MILES
The engine is turning but not starting:
repalced spark plugs
tested the following:
1- electrical spark: OK
2- Pressure on fuel line (seems OK), a small valve on the fuel line despenses gas when pushed. Pressue gets built up again, after attempting to crank
How can I test for crank shaft sensor, or what to do next?
Sunday, February 15th, 2009 AT 3:13 PM
JDL
  • 16,098 POSTS
Hello, I'm not sure of the litre size of the engine? With the engine cranking, is there an injector pulse? You really need a fuel pressure gage to check fuel pressure. Right now, I think the crank sensor is ok. It is possible for the ignition module to see the pick-up signal, but, maybe the computer doesn't see it, for some reason. You need to know if the computer sees an rpm signal. Without a scanner, look for injector pulse.
Can you check for codes?
Sunday, February 15th, 2009 AT 3:32 PM
