2002 Oldsmobile Bravada Engine cuts off
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
LICIE25
When ever I start my truck and cut the heat/cool on my truck automatically cuts off. However when I'm driving on the freeway I can cut the the heat/cool on and the car does not cut off. Only when i'm stopping or not driving at a high speed. It be hesitant and then it cuts off. Why is that, I took it to many places and no on can tell me what's wrong. Can you help?
Oct 29, 2010 at 9:23 AM
HMAC300
  • 48,601 POSTS
try cleaning the throttle plate with choke cleaner as they tend to gum up andcause issues like yours. I'd suggest running a scan on the engine to see if any codes are present. Make sure to clean the plate on both sides......
Nov 2, 2010 at 12:49 PM
