1999 Oldsmobile Bravada motor cutting out
ROXYZ
  • 1999 OLDSMOBILE BRAVADA
  • 6 CYL
  • AWD
  • 86,000 MILES
When it is above 80 degrees.
The engine starts cutting out, then stalls. (Doesn't over heat)
After sitting, (last time for an hour & a half) it will start.
I had a fuel pump & filter installed @ 75,000 mi. Last yr.
Could it be oxygen position sensor?
Saturday, July 18th, 2009 AT 5:38 PM
BUDDYCRAIGG
  • 2,262 POSTS
Next time it doesn't start, check for spark.
Those are classic signs of the ignition module failing.
Saturday, July 18th, 2009 AT 8:52 PM
BUDDYCRAIGG
  • 2,262 POSTS
I tried to email you back, but your email server rejected my message.
So please respond in the thread here.
from OP via email.
How did you check for spark when it would not start?
Sunday, July 19th, 2009 AT 9:33 PM
