1998 Oldsmobile Bravada
1998 OLDSMOBILE BRAVADA
185,000 MILES • 6 CYL • AWD • AUTOMATIC
JIMBO1951
Over heating. Replaced thermostat. Still overheating. Took out thermostat and ran. Still overheating. Water pump 3yrs old. Radiator 2yrs old. No major leaks visible. No water in oil. Engine clanks alot when starting. White smoke comming out tail pipe. Help!!
Dec 2, 2008 at 2:08 PM
SWILLIAMS
  • 597 POSTS
White smoke out the tailpipe and clanking sounds are not good. Sounds like a blown head gasket and possibly internal engine damage due to hydro-lock. I would run a pressure test and pull the plugs to check for water in a cylinder. Also check for combustion gas in the coolant.
Dec 14, 2008 at 11:38 AM
