2001 Oldsmobile Aurora won't start
TINMAN332
  • 2001 OLDSMOBILE AURORA
  • 6 CYL
  • FWD
  • 72,000 MILES
If I try to start it soon after it has been shut off completely dead, no crank, nothing. Will sometimes start if I put the car in neutral. If I leave it alone for an hour, starts right up. Is this a pass lock system problem? Is there a way to reset the system?
Wednesday, December 17th, 2008 AT 11:42 PM
  • 109,885 POSTS
Hi
If the car starts in neutral, chances are it's the neutral safety switch. However, does it always restart eventually? Also, when it doesn't start is the security light flashing when you turn the key? Do the dash lights come on when it doesn't start?
Sunday, December 21st, 2008 AT 9:12 PM
TINMAN332
Hi Joe,
Yes, the car does restart eventually, in Park, if you leave it alone for about an hour. The security light is flashing and the dash lights do come on when it doesn't start?
Maybe a problem with the pass-lock system?
Thanks for your help, I really appreciate it.
Barry
Sunday, December 21st, 2008 AT 9:37 PM
  • 109,885 POSTS
Barry:
The problem sounds like the security system is locking you out. There is a small resister in the key that the sensor (in the steering column) recognizes. If either is weak, the engine looses spark and fuel preventing the car from being stolen. If you have another key, you may want to try it. If not, you will need to contact a dealer that has the necessary test equipment. The flashing security light is the indicator as to where the problm lies.
Monday, December 22nd, 2008 AT 3:10 PM
TINMAN332
Great advice. Thanks, Joe!
Wednesday, December 24th, 2008 AT 10:58 PM
