1997 Oldsmobile Aurora p0340 camshaft position sensor
1997 OLDSMOBILE AURORA
TBJR50
Computer problem
1997 Oldsmobile Aurora V8 Front Wheel Drive Automatic
I recently had my car repaired at an automotive repair shop for the above code. they replaced the sensor,computer,and fuel pump but were unable to clear the code aftechecking over all possibilities. should I take the car to a gm dealer?
Aug 10, 2008 at 1:28 AM
  • 31,937 POSTS
Hi there,
if they are unable to clear the codes, you should get that done at a dealer or a general shop with that equipment.
Mark (mhpautos)
Aug 10, 2008 at 2:22 AM
MR62BUICK
  • 12 POSTS
Actually, the sensor in the rear head only does the initial sensing. The Ignition control module (holds the coils) is the culprit. I replaced mine after replacing the sensor first, then after replacing the ICM, it went away and runs great. Unfortunatly, the ICM is roughly 500-700 dollars. I bought a used one off ebay for $50 and it even came with a warranty. Good luck!
Feb 25, 2009 at 12:05 AM
