I seem to be leaking coolant but not on the ground...could it be leaking into the oil? and what problems can that cause?
Mar 24, 2010 at 12:49 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
If you don't see the leak, check the engine oil. If it is, it will have a slimmy light brown / white look to it. Also, check the exhaust for white smoke. That would indicate the coolant is making its way into the combustion chamber.
