1996 Oldsmobile Aurora Leaks oil and radiator fluid
16,600 MILES • 6 CYL • 2WD • AUTOMATIC
KYLE4242
the radiator fluid and oil both leak out. and when I drove it 1000km from calgary to vancouver it kept overheating every 1-2 hours where i would keep feeling it with water. It also started have a faint knocking sound when i accelerate from a stop. Is this going to cost me alot to get fix and is it a bigger problem then just the leaks
Mar 25, 2009 at 7:22 PM
BLACKOP555
  • 10,386 POSTS
wheres the oil leaking?
if its going in with antifreeze with oil or oil with antifreeze i would suspect a cracked block or blown headgasket.
youll need to do a compression test to verify what it is.
how hot is it running? how about excessive white exhaust?
Mar 26, 2009 at 7:54 AM
