HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Aurora
Engine
Starter
Replace/Remove
1995 Oldsmobile Aurora starter
BREWMASTER87
MEMBER
1995 OLDSMOBILE AURORA
V8
FWD
AUTOMATIC
185,000 MILES
Starter went out need info on how to change it.
Thursday, January 15th, 2009 AT 8:28 PM
MECHANIC
Hi:
Disconnect the neg terminal from the battery. Next, remove the wiring from the starter, remove the two bolts holding it on to the engine, and remove the starter. Reverse the order to replace.
SPONSORED LINKS
Thursday, February 19th, 2009 AT 7:09 PM
Please
login
or
register
to post a reply.
Related Starter Replace/Remove Content
1995 Oldsmobile Aurora Electrical Nightmare (more...
Electrical Problem 1995 Oldsmobile Aurora V8 Front Wheel Drive Automatic I Am Working On A '95 Aurora. First Off, The Polarity Is...
Asked by
D.J.
1 ANSWER
1995
OLDSMOBILE AURORA
VIDEO
Starter Replacement
Instructional repair video
GUIDE
Starter Motor Replacement
A starter motor is a high torque motor that utilizes a small pinion gear to contact the flywheel and a starter solenoid to initiate the electrical connection when the...
1995 Oldsmobile Aurora Starter
I Need To Know How To Change The Starter On My 95 Oldsmobile Aurora.
Asked by
jeniann
1 ANSWER
1995
OLDSMOBILE AURORA
Location Of Starter Safety Switch On 2001 Aurora V8.
Will Not Start When Ignition Switch Is Turned To Start. Used To Start If Shift Lever Was Giggled, But Now Nothing Works. I The Switch...
Asked by
Joe Fernandez
1 ANSWER
2001
OLDSMOBILE AURORA
Starter
My 98 Olds Auroa Will Not Turn Over At All, Battery Is Good, Thinking Maybe Brushes Hung Up In Starter, Where Is It Located And Can I Tap...
Asked by
bearman 65
1 ANSWER
1998
OLDSMOBILE AURORA
1996 Oldsmobile Aurora Starter
I Need To Rermove The Stater To Get It Tested But I Cant Find It Once I Get Under The Car
Asked by
gqalawishes
1 ANSWER
1996
OLDSMOBILE AURORA
VIEW MORE
SPONSORED LINKS
Starter Replacement
Starter Replacement
Online car repair manuals
