1995 Oldsmobile Aurora Battery Replacement
HERLINDA
Other Category problem
1995 Oldsmobile Aurora V8 Wheel Drive Type unknown Automatic 162,00 miles
Where the heck is the battery on this car! (It's not under the hood) Someone told us it was behind a panel behind one of the front tires but we've taken them both off and don't see a panel, only metal with lots of rivets!
Jan 30, 2008 at 3:09 AM
WYOOLDS
Herlinda, this puzzled me too because I did not have the Owner's Manual. Then another Aurora owner told me the battery is under the back seat! Just pull up on the front of the seat and pull the seat out. The battery is about $100 to replace because it is big and has side posts only. I got one at Autozone but had to special order it. There is a positive battery terminal under the hood on the left side for jump starting the car or another vehicle. Clamp the negative jumper cable on the engine block hook used for hoisting the engine....
Feb 6, 2008 at 4:15 AM
