1996 Oldsmobile Aurora Keeps Draining the car battery
175,000 MILES • V8 • 2WD • AUTOMATIC
BJAY1101
I replaced the car battery and the battery keeps losing wattage, after a day its not enough energy to start the car
Nov 3, 2009 at 8:41 AM
IMPALASS
  • 3,112 POSTS
Hello –
Make sure your battery has a really good charge. Then please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
The big thing here is them checking your alternator to see if it is not putting out enough to charge your battery while driving it.
Nov 3, 2009 at 10:17 AM
