1995 Oldsmobile Aurora
JOEZEPI
  • 1995 OLDSMOBILE AURORA
  • V8
  • FWD
  • 75,000 MILES
I HAVE A 95 AURORA AND IT WILL RUN FINE THEN AFTER A 5-6 DAY PEROID IT WILL JUST DIE AND NOT START. AT THE SAME TIME WHEN TRYING TO START THE FUEL GAUGE IN THE CAR WILL DROP TO EMPTY WHEN CRANKING IS THEY SOME GAS SENSOR AND WHERE IS IT LOCATED BECAUSE WHEN THE FUEL GAGE DOSE NOT DROP WHILE ATTEMPTING TO START IT WILL FIRE
Saturday, January 9th, 2010 AT 10:02 AM
ERNEST CLARK
  • 1,730 POSTS
The first thing to check is whether or not you have fuel pressure when you experience this problem. You'll need a fuel pressure gauge. Hook it to a service port on your fuel rail and turn your key to the "ON" position. You should hear your pump running.
If you don't, and/or you have low fuel pressure, check your fuel pressure regulator next. You'll need a vacuum gauge. Hook it to the vacuum port that's on the regulator and apply 10 inches of vacuum. If it holds without dropping, then that's fine. If not, replace it.
If the regulator checks out, but you have low pressure, then the pump is bad.
Your fuel pump, sending unit and in-tank screen is a one-piece assembly located in the trunk.
To gain access, pull up your carpet and you'll see a fuel access panel up by your rear seats.
Remove the pump and replace it as a complete unit.
Saturday, January 9th, 2010 AT 1:22 PM
