2004 Oldsmobile Alero Air Conditioning & Rear Defrost
2004 OLDSMOBILE ALERO
BIGGSEY
Air Conditioning problem
2004 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
A/C and Rear Defrost buttons light when pushed but neither the A/C nor the Rear Defrost will work.
Any ideas?
I've checked fuses and relays...
Is there a fuse in a line somewhere or maybe a wire pulled loose?
I find it odd that neither works and the buttons are beside each other...
May 27, 2010 at 10:18 AM
FACTORYJACK
  • 4,159 POSTS
When you energize the A/C first of all, do you hear the compressor relay operate. The compressor relay is controlled by the engine control module, with that being said, if there are faults within the PCM(current or history) it can inhibit the operation. The all out best way to check this would be with a scan tool, you could also control the compressor relay with the scan tool that will get you further in diagnosis. If the system is low on charge, the ECM will also inhibit operation.
Same on the rear defogger, can you hear the relay click?
If it does, or does not, swap it with a similar relay in the underhood fuse block and recheck. The circuit goes through the antenna amplifier(probably because the grid acts as the radio antenna as well. The next step would be to go to that amplifier and check for power on pin 1, a black wire, with a test light to ground. If there is power there, check at the grid, also with a test light to ground. If there is power at the grid, check the continuity to ground from the grid, with an ohmmeter. Let me know the results.
May 27, 2010 at 5:17 PM
BIGGSEY
Perfect!!! Checked Relays... Rear Defrost needed replaced. A/C needed charged. Everything is working great now!!!
Thank you so much for helping me to feel the cool air again!
May 28, 2010 at 6:15 AM
FACTORYJACK
  • 4,159 POSTS
That's Great!! Glad you could get it resolved, and with minimal complication. Thanks for the participation.
May 28, 2010 at 3:49 PM
