2004 Oldsmobile Alero REAR DEFROST
ALL84
2004 Oldsmobile Alero 6 cyl Automatic 93000 miles
I CANT GET MY REAR DEFROSTER TO WORK. WHAT SHOULD I DO BEFORE TAKING IT IN?????
Jun 18, 2010 at 7:28 AM
GMTECH
  • 537 POSTS
You could check to see if there is power to the defroster grid. It is possible to have a radio antenna module problem. It is mounted by the rear glass, it splits the antenna signal from the defroster. You could also have a control head issue.
Oct 25, 2010 at 1:12 PM
