2001 Oldsmobile Alero lower pulley
JOSEDELEON
2001 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
how i can change the lower pulley where my serpentine belt goes?? for some reason it looks it is out of alligment from the others... make sense??
Feb 18, 2009 at 1:10 AM
  • 110,246 POSTS
Are you refering to the harmonic balancer? If so, there is a bolt in the center that needs removed, and then you will need a puller to get it off. If you only need the pulley off, I believe there are three or four bolts into the harmonic balancer that need removed and the pulley will come off.
Let me know if this helps.
Feb 19, 2009 at 8:18 AM
