A Knock sensor? out of no where my car just would not start?
GRAYC
Ok I have had so many problems with my Alero it aint funny. I have put so much money into it that im sick of it. I have put 2 fuel pumps in it, power steering pump, spark plug coils, ignition wires all over the past 2 years. Anyways out of no where my car just would not start. It will start for a few seconds then die, once I try it again it only turns over. I used a computer read and it says 3 O2 sensors no activity and a knock sensor. I want to know if a knock sensor can do that to your car? Im trying to fix this problem myself instead of putting it in a shop and spending hundreds of dollars yet again...so can yall help me and tell me if a knock sensor can stop a car from starting?
Feb 9, 2009 at 2:05 AM
  • 110,248 POSTS
Hi:
A knock sensor advances timing to a point right before it you get valve ping and the car is running it most efficient. In theory, it could send a false reading to the computer and trick it into retarding or advancing the timing to a point to where it won't start. But truly, I never saw it before.
Let me know if you have other questions. To me it sounds like it's starving for fuel again. Will it start for a few seconds with starting fluid?
Feb 19, 2009 at 8:51 AM
AMANDA PROMISE POTTS
My Alero did the exact thing. Would start and immediately shut off. It ended up being the body control module. Starts every time now.
Jul 23, 2022 at 10:47 PM
  • 55,604 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Jul 24, 2022 at 5:19 AM
