2001 Oldsmobile Alero ignition switch
73,000 MILES • 6 CYL • FWD • AUTOMATIC
CRAZYALEROS
Can anyone tell me how to replace the ignition switch, my key was stuck in the off position and the steering is not locked, I was told that I needed a new ignition but first you would have to get the key in the on position to be able to push a button to release the switch. Where is this button that I need to press?
Apr 29, 2008 at 11:52 AM
2CARPRO JACK
  • 11,533 POSTS
cant find any pics for that in my software. Once you get to the ignition switch assembly, it just says "depress tab to remove tumbler assembly" should be the only tab on the switch assembly
Apr 30, 2008 at 12:38 AM
CRAZYALEROS
[quote:65d8f60e34="2CarPro Jack"]cant find any pics for that in my software. Once you get to the ignition switch assembly, it just says "depress tab to remove tumbler assembly" should be the only tab on the switch assembly[/quote:65d8f60e34]
Thanks for your time, we found that out once I purchased the new one. So hopefully its as easy as it sounds!!
Apr 30, 2008 at 12:34 PM
2CARPRO JACK
  • 11,533 POSTS
Good luck... shouldnt be too difficult
May 1, 2008 at 12:25 AM
