2001 Oldsmobile Alero Car won't start
REBECCA2001
  • 2001 OLDSMOBILE ALERO
  • 6 CYL
  • FWD
  • 175,000 MILES
Changed spark plugs and wires on my car, and went to start it up and it refuses to start. Checked all the plugs and wires to make sure everything was hooked up properly then noticed that when we turn the key we don't hear the fuel pump like we did before.
Unhooked the battery for 24 hours to reset the computer and the car still won't start. Smacked the gas tank today with the key turned on and nothing.
Wondering what other things do we need to check? Car was running until the plugs and wires were changed.
Tuesday, September 28th, 2010 AT 3:42 PM
Check fuel pump Inj fuse 15amp in underhood fuse block and fuel pump relay same location
Tuesday, September 28th, 2010 AT 5:18 PM
REBECCA2001
Checked the relay fuse and still nothing.
Does this mean it is the fuel pump?
Wednesday, September 29th, 2010 AT 7:39 PM
Power the fuel pump direct from the battery and see what happens.
Thursday, September 30th, 2010 AT 4:10 AM
