2000 Oldsmobile Alero OVERHEATING
TXSWANGA86
  • 2000 OLDSMOBILE ALERO
Engine Cooling problem
2000 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
i changed the thermostat n cleand my radiator n still heats up
Tuesday, July 13th, 2010 AT 2:42 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Are cooling fans operating? Is it boiling over? How long of engine operation does it take? Any coolant loss?
Let me know
Thanks for donate
Tuesday, July 13th, 2010 AT 3:07 PM
Check the cooling fan if its working properly and the water pump if okay and its not being caused by airlock in the system, Get it block and pressure tested to rule out a blown headgasket, cracked head or block and an intake leak
Tuesday, July 13th, 2010 AT 3:09 PM
