2000 Oldsmobile Alero over heating issue
DGIGGLES1
  • 2000 OLDSMOBILE ALERO
Engine Cooling problem
2000 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
2000 Alero 3.4 had it in the shop it was gurgeling thru the radiator the mechanics checked for air in the system, replaced thermostat, didn't fix. Next step was pulling the heads, they were warped, had heads machined, when put back together seemed ok, now over heating again?
Friday, August 13th, 2010 AT 6:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Overheating caused the heads to warp. Are the cooling fan(s) coming on properly? Can you feel coolant flow being pushed through by feeling radiator hoses?
Friday, August 13th, 2010 AT 6:54 PM
DGIGGLES1
  • 23 POSTS
I think it may be a collapsed radiator hose, could that be the issue causing restriction and no flow making it over heat?
Friday, August 13th, 2010 AT 7:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes that will definitely cause it.
Friday, August 13th, 2010 AT 7:47 PM
DGIGGLES1
  • 23 POSTS
Thanks I will check into it and go from there! Thanks again
Friday, August 13th, 2010 AT 7:56 PM
DGIGGLES1
  • 23 POSTS
OK, the bottom hose was collapsed, now I have replaced both the top and bottom radiator hoses and I am still getting a small gurgling out of the over flow? What am I missing here?
Saturday, August 14th, 2010 AT 7:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Did you purge cooling system of air after repacing hoses? The radiator cap may be bad also, not sealing good will cause gurgling.
Saturday, August 14th, 2010 AT 7:39 PM
DGIGGLES1
  • 23 POSTS
The cap and thermostat have been replaced, I don't know what else to check that would make it stop over heating
Sunday, August 15th, 2010 AT 9:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/first_things/engine_over_heats.htm
Sunday, August 15th, 2010 AT 3:43 PM
