1995 Oldsmobile Achieva Must turn over engine 5-8 times to
90,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVE GARSKE
Must turn over engine 5-8 times to get it to start, once it starts it seems to run fine??? I already changed fuel filter, air filter. I was told it was the fuel pump but I can hear the fuel pump go on when I turn the key. Any idea what to check next?
Oct 5, 2009 at 9:34 AM
  • 110,244 POSTS
Chances are there is a leak in the system that allows the fuel pressure to drop off when you shut the key. Here is a how to for checking pressure and fuel pressure drop off. Give it a try paying close attention to how quickly the pressure drops off when the key is shut.
You will need a gauge to check this, but most parts stores will lend or rent them. If you can't find one, they sell them from this site at great prices.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Oct 10, 2009 at 5:17 PM
