1995 Oldsmobile Achieva Head gasket
1995 OLDSMOBILE ACHIEVA
JAP3MILLER
Engine Mechanical problem
1995 Oldsmobile Achieva 4 cyl Two Wheel Drive Automatic
I've been given a 95 Olds Achieva with a blown head gasket. I bought new ones and the tool to hold the cams in place. But now i'm trying to tear into it, but was stopped before i started by noticing that the ENGINE MOUNT was in the way of removing the Timing cover. My question is simply do i have to pull the motor to replace this gasket, or could i put a jack under the engine and and remove the motor mount that's in my way and procced from there?
Jan 24, 2009 at 9:35 AM
BILLYMAC
  • 2,204 POSTS
hi yes support the eng with a jack and be POSITIVE you use a board between the jack and the oil pan as the pan is aluminum and will break.this is a very complicated head gasket you will need a service manual good luck billymac
Feb 28, 2009 at 12:47 PM
