1995 Oldsmobile Achieva Clunking
1995 OLDSMOBILE ACHIEVA
279,000 MILES • 6 CYL • FWD • AUTOMATIC
RUTRO
When I suddenly accelerate to about half of the way the peddle goes down I hear a "clunk clunk clunk clunk clunk" from the front end of the car (it seems like it is coming from under the hood). The car does not make any clunks or clicks when the wheels are turned while not moving, and it does not make the clunking noise when revved out of gear. The car does not make any strange noises when deaccelerating either, no matter how sudden. The CV joint boots look fine, or at least untorn.
Does this sound like a CV joint problem? Many of the symptoms of a bad CV joint except for the clunking and vibration at certain high speeds (I think I have a bent rim) do not seem to fit. What else could be bad?
Feb 28, 2009 at 12:09 PM
BILLYMAC
  • 2,204 POSTS
hi yes this could be a cn joint that is bad although the boots are not torn.and a axle can cause a vibration as well.put the car in the air and run in drive see if axles make noise then,..sometimes the only way to find a prob like this is to completely remove the axle and check it over really good..billymac
Feb 28, 2009 at 12:16 PM
RUTRO
Thank you for your reply!
Feb 28, 2009 at 5:16 PM
