transmission shutters when it shifts in 1 or 2nd. could it be the filters clogged or the clutch
Nov 28, 2008 at 3:18 AM
✓Experienced Mechanic
Hi:
If it only shudders when it shifts and not in a higher gear under a load, chances are the clutches are ok. You may want to try servicing it with a quality shift improvement additive.
Let me know if it helps.
Dec 20, 2008 at 1:21 PM
