Cylinder not firing.
LAKEMAN2010
  • 1990 OLDSMOBILE 98
  • 170,000 MILES
I have a Olds 98 with 170,000 miles on it. The car start and runs good with no warning lights or that type of thing. But twice now when I have gone to start it the car will turn over fine but will not start. Both times this has happen at night. When I have gone out the next morning to see what is wrong with the car it starts and run fine. It has not start twice now with about three weeks in between. What should I be looking for that could be causing this problem?
Wednesday, November 1st, 2017 AT 7:59 PM (Merged)
RIVERMIKERAT
  • 6,110 POSTS
Fuel injector or ignition relay failure. No fuel pressure when the problem occurs. No spark when the problem occurs.
LAKEMAN2010
How do I check these when the cars is running fine?
LAKEMAN2010
How do I check these out when the car is running fine?
RIVERMIKERAT
  • 6,110 POSTS
You don't. You check them when the problem occurs. Use a test light to check for injectors being pulsed. Use a screwdriver in the plug wire to check for spark. A fuel pressure gauge is needed to check fuel pressure.
GDUTCHNAK
  • 1989 OLDSMOBILE 98
  • 6 CYL
  • FWD
  • 35,000 MILES
Engine Mechanical problem
1989 Oldsmobile 98 6 cyl Front Wheel Drive Automatic 35000 miles
I just bought a 1989 olds98 at an estate auction. The car has 35000 miles on it. It will start if I spray starting fluid in it but then dies once the fluid runs out. I have not worked on this car yet in fact I haven't brought it home yet because it won't stay running
LEGITIMATE007
  • 5,121 POSTS
Try to listen, to the fuel pump come on when you turn the key to the on position, I have a feeling that you have a bad fuel pump. You may also want to check the fuel pump relay too. Before condemning the pump
