1995 Oldsmobile 88 loosing water intermittently
1995 OLDSMOBILE 88
100,000 MILES • 6 CYL • FWD • AUTOMATIC
CSPIVEY74
changed intake manifold gasket r/t intermittently loosing water, no external leak seen. continues doing the same thing. about year ago car water lock the cylinders, mechanic changed " bladder" is he referring to upper intake. what ohter things could it be
May 25, 2010 at 9:43 AM
2CARPRO JACK
  • 11,533 POSTS
Some of those 3.8L engines had issues with the intake getting eaten away next to the EGR port. This can cause water consumption without any visible leakage.Also check the water pump weep hole (bottom of pump) for stains or other signs of leakage,Sometimes water pumps will only leak at certain times (when running) so you dont see anything hit the ground. Beyond that, might want to have the system pressure tested to see if it holds
May 26, 2010 at 1:19 AM
