I don't known if it's electrical or mechanical when it's wet weather it will shut down and wii not start until whatever gets dry.
Monday, March 30th, 2009 AT 10:27 PM
JAMES W.
MECHANIC
You'll need to determine what is missing when the no start condition exists, ie. Fuel pressure, spark, injector pulse or any combination of the three. I'm going to assume it's spark. Buy yourself a small tube or silicone or dialectric grease. Romove the connectors around the coil pack. Make sure they're clean, grease them up and put back together. You'll know if you got it the next time it rains. Hope this helps.
SPONSORED LINKS
Tuesday, March 31st, 2009 AT 1:57 AM
DUSTY61
MEMBER
It's getting fire from plugs +wire plus fuel when you are cranking but will not start.
Tuesday, March 31st, 2009 AT 9:01 AM
JAMES W.
MECHANIC
OK, but, are you getting a pulse to the injectors to fire them? You can check this with an ordinary test light a the injector connector as you crank the engine.
Tuesday, March 31st, 2009 AT 12:40 PM
DUSTY61
MEMBER
Fuel pressure good, sparks to plugs are good when you are cranking. (Won't start)
Thursday, April 2nd, 2009 AT 10:39 AM
JAMES W.
MECHANIC
You still need to check injector pulse. If the ECM isn't firing the injectors, it's not going to start.
