1995 Oldsmobile 88 All interior electrical systems appear d
1995 OLDSMOBILE 88
115,000 MILES • 6 CYL • FWD • AUTOMATIC
KINGPIN23
In Janurary I was idleing the car to warm it up. When I got in the car the engine temp showed 200 on the dash but the heater was blowing ice cold. I had just installed a new thermostat and it had ben working fine for a week or so. When i put the car in reverse the engine died. When I attempted to restart, the ignition just clicked and would not crank. I assumed this to be either a starter or battery issue. The battery showed only 9 volts when checked, so I removed it from the car and had it tested at a parts house, it tested good and they recharged the battery. I was injured before I could put the battery back in the car, so the car has sat without a battery for the last 3 months...Now, I have finally been able to try and get the car running. I have again recharged the battery and have 13 volts at the alternator and at the starter. However the interior of the car is dead. The ignition does nothing when turned over, no dash lights, no radio, no headlights, no nothing! Could this be a fusable link, computer, relay, or what??? I'm at a loss for what to do next. Please Help! The car ran great prior to this.
Apr 28, 2010 at 11:00 AM
ENGINE_JOE
Based on your description of events, most likely something isn't connected. Different systems (lights ignition, etc.) operate on different fused circuits where the battery is the only common source of power. There is no single, main fuse. If there was a fuse or fuse link problem, something, somewhere in the car would work.
If nothing at all works, make sure the battery is installed correctly and all necessary wires are connected.
Once you get that solved and you can start the engine again, you might want to check the charging system and find out why the battery went low in the first place. If the battery tested good, that suggests the charging system wasn't working.
Apr 28, 2010 at 3:36 PM
