1994 Oldsmobile 88 Wont stay running
1994 OLDSMOBILE 88
78,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBW19703
I can start the car in the yard but if I try and drive it more than 3 mile, it begans to shut off. I know that I have a problem with my brake, I was told the master cyn went bad. So I as I was driving a warning bell has been going off. My question is there a safty system that would shut the engine off if it is reading that I need brake work?
Aug 9, 2010 at 2:01 AM
  • 110,240 POSTS
No, that won't happen. Has the check engine light come on? Have you checked fuel pump pressure?
Aug 13, 2010 at 2:21 PM
ROBW19703
So I should just change out the fuel pump and then the master cyn. Will the filter be a possibility? Thany you so much for your help
Aug 16, 2010 at 12:18 AM
  • 110,240 POSTS
If the brake pedal goes to the floor and there are no leaks, yes, replace the master cylender. As far as the fuel pump, I recommend checking it before replacing it. It isn't a fun job.
Aug 16, 2010 at 4:04 PM
