1995 Oldsmobile 88
MACIEL
  • 1995 OLDSMOBILE 88
1995 Oldsmobile 88 6 cyl Front Wheel Drive
this vehicle came in for a turn signal switch changed the switch and now it will not start I have spark noid but no fuel pressure also no power going to fuel pump
Wednesday, January 21st, 2009 AT 12:08 PM
JDL
  • 16,098 POSTS
I'd check fuse 6, 20 amp, in the relay center, that circuit goes hot with the key in the run or crank position.
My info shows a prime connector for the pump, if you run b+ to the connector, the pump should run like crazy, you don't need to crank it. The connector may be by the battery, red wire.
Wednesday, January 21st, 2009 AT 3:31 PM
