Turn Signals
1996 OLDSMOBILE 88
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVEBETTY2
when turning signals on either right or left all bulbs illuminate on both sides, back and front but neither side has flashing action have checked small 20 amp fuse in fusebox and also checks out ok
Sep 13, 2009 at 4:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
do the hazard lamps blink properly?
test your vehicle's turn signal flasher relay, located on left kick panel.
Sep 13, 2009 at 8:13 AM
STEVEBETTY2
turn signal relay replaced which fixed turn signals.However new problem now.Car will not start.security system appears to be over-riding on dash display as security blinking on display.any ideas how to override and what may have caused this to occur
Sep 15, 2009 at 8:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You may need to relearn the anti theft,
Read the guide below, it will tell you how
https://www.2carpros.com/articles/how-to-reset-a-security-system
Apr 1, 2019 at 1:00 PM
