Oil leak
440,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JERISAN
Hello, I have an old truck that started knocking. checked oil and there was none, filled it with cheap Walmart oil 10w30 (what was recommended by spec) and kicked it over almost immediately white smoke came out and never stopped. After shutting it off the oil drained out of somewhere. Cannot locate any cracks in the metal. Checked oil level, almost nothing is left. Stopped driving it and it has been sitting in front of my house for over a year. Before this the transmission had been rebuilt and it was very powerful. I do not know what to do. Is it worth repairing?
Oct 28, 2017 at 6:37 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
White smoke coming out where? the tailpipe? If so, that usually indicates and blown head gasket.
If you fill the engine full of oil right now where it sits, does the engine leak oil, without starting the engine?
Oct 28, 2017 at 6:41 AM
JERISAN
smoke from tailpipe, yes. I have not tried to fill it with oil again since
Oct 28, 2017 at 7:32 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Is this a dual exhaust or not?
If dual, and it only smokes white out one tailpipe, then the side that smokes has the blown head gasket on that side in between the cylinder combustion area and the coolant passage and coolant is entering the combustion chamber and getting burned.
Put 5 quarts of motor oil in the engine and try to see what is leaking.
Oct 28, 2017 at 7:41 AM
JERISAN
Single exhaust will fill oil ASAP.
Oct 28, 2017 at 8:01 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Of course you do not need the entire five quarts if it starts leaking after just one quart, so add one quart at a time.
Oct 28, 2017 at 8:49 AM
