Oil pressure sending unit location?
LLATHAN
  • 8 POSTS
  • 1998 CHEVROLET MALIBU
  • 4 CYL
  • 109,113 MILES
I have a 1998 Chevy Malibu. My oil sending unit is leaking oil. How did this happen and what can I do to fix it. My car has 109,000 miles and it won't start. I didnt have any problems until Jiffy Lube forgot to replace my oil cap.
Monday, September 7th, 2020 AT 2:07 PM (Merged)
  • 110,176 POSTS
The sending unit is most likely leaking because of age / miles. The part has one wiring harness to it. Disconnect it and the unit unbolts. Reverse the sequence to replace.
Okay, keep me updated.
LLATHAN
  • 8 POSTS
Thank you for your fast and accurate response. I wanted to make sure this mechanic was doing the right thing. The car still won't start. I do have an anti-theft system problem as well. For months I would try to start my car and the theft system light would come on. I had to wait about ten minutes and it would start right up. Now the car doesn't do that anymore. I have to wait hours before it will start up. Can I use a bypass kit or is the problem more severe?
STEPHANI JOHNSON MCDANIELS
  • 5 POSTS
I replaced the sensor. Which was not super fun and it's a whole lot better. My rpm gauge has stopped working and now it's working again. It smoked a little bit when I started it the first time but that was it. It still had a second of delay to start but that is a whole lot better than it was. Thank you so much for your help. I think replacing the starter is next just to be on the safe side.
  • 110,176 POSTS
As far as the security system, you need to have it tested at a dealer. They are the only ones with the proper test equipment to check it. To the best of my knowledge, it can't be bypassed.
You are welcome.
Always glad to help.
  • 110,176 POSTS
NOTE: By waiting for 10 minutes with the key in the run position, you are bypassing the security system. If that no longer works, you need to have a dealer check the system. They are the only ones with the proper test equipment.
