2006 Ford F-150 Oil Viscosity
AUTOMATIC
TEE WALL
Can I use sae 10w-30 and or 10w-40? I came across some oil at my parents they wouldn’t be using and I’d hate for it to go to waste if I can use this to save money.
Nov 1, 2026 at 12:58 PM
MECHTRIX
  • 595 POSTS
The factory recomendation for that vehicle is 5.20 fully synthetic .
Nov 1, 2026 at 2:34 PM
  • 55,770 POSTS
Here's how the different oil grades compare:
5W-20: Ford's recommended viscosity and the best choice for normal operation.
5W-30: Slightly thicker at operating temperature, but not the specified grade.
10W-30: Thicker during cold starts and at operating temperature. I wouldn't recommend it for a complete oil change.
10W-40: Considerably thicker and not recommended for this engine.
If you're simply topping off an engine that's low on oil, a small amount of compatible 10W-30 would generally be preferable to running the engine with insufficient oil. I would not use either 10W-30 or 10W-40 for a complete oil change.
Nov 2, 2026 at 7:25 AM
Suggested Repair
Use the factory-specified 5W-20 fully synthetic oil. Do not use 10W-30 or 10W-40 for a complete oil change. A small amount of 10W-30 is acceptable only to top off a low engine, and is better than running with insufficient oil.
Conversation Summary
The owner of a 2006 Ford F-150 asked whether leftover 10W-30 or 10W-40 could be used instead of the specified oil to save money. Experts said the factory recommendation is 5W-20 fully synthetic. 10W-30 and 10W-40 are thicker than specified and are not recommended for a full oil change; a small amount of 10W-30 is acceptable only for topping off if the oil level is low.
