1995 f150 5.8L oil pump
1995 ALL OTHER MAKES ALL OTHER MODELS
PIT_BULL_1987
hi i need some help, if any one could tell me how to change my oil pump in my f150. It is a 1995 4x4 ext cab 5.8 L . if any one has any hints on how to do this(ie the oil pan out from under the engine with out taking tranny out) that would be a big help. Thanks Mark :?
Dec 29, 2006 at 2:49 PM
ABADAY
  • 38 POSTS
remove the fan shroud and upper intake remove exhaust pipes motor mount bolts and lossen trans bell bolts remove oil pan bolts lower pan on to cross member remove pick up tube and screen and place in oil pan then remove pan ALOT OF WORK
Dec 30, 2006 at 11:57 AM
INDYUKE
  • 416 POSTS
I recently replaced the oil pump on my '91. I also needed to remove upper intake manifold in order to jack engine up the required 5 inches so the oil pan can clear the crossmember. I've thought it was possibly easier to remove the entire engine, flip it over and go from there. Good luck.
Dec 31, 2006 at 11:51 AM
