Oil Pressure Stop Engine red light
107,400 MILES • 1.8L • 4 CYL • AUTOMATIC
LUIS GUEVARA
  • 5 POSTS
Hey guys. This is a bit tricky but I hope you can help me. The light came on like a month ago and it had never appeared before. So I added oil, the light went off, I drove a full day and no light, then the next day I turned it on again. To make a long story short, I changed the oil pressure gauge on it, Ive been complying with the oil changes every 5,000 miles. I'm an Uber driver who drives 10 hrs from Monday through Saturday, so I need this car to be in tip top shape. Yesterday I drove it after the gauge was changed and nothing no light, today it turned on again and now I don't know if it could be the oil pump or a clogged valve or a faulty sensor. What do you guys think? Funny thing is that it comes and goes, my mechanic friend turned on the engine and saw the inside of the engine and we could see the oil working fine. I'm hoping its something simple and NOT the oil pump. Thanks guys.
Apr 22, 2016 at 7:22 AM
SATURNTECH9
  • 30,869 POSTS
So you changed the gauge in the instrument cluster or the oil pressure sending unit?Also you would really need to check the actual pressure to see if it's normal when the light comes on.Your friend that works on cars should be able to help with that and surprised he didn't mention that.
Apr 22, 2016 at 1:59 PM
LUIS GUEVARA
  • 5 POSTS
Yeah he didn't mention that because he's a thief lol. I'm not going back with him. And I do not know which oil pressure part he replaced, he did show me the part though, it looked like a small screw to me. Does that help?
Apr 23, 2016 at 12:52 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like the oil sending unit I would have the oil pressure tested.
Apr 23, 2016 at 1:45 AM
LUIS GUEVARA
  • 5 POSTS
Alrighty I did have the oil pressure tested and it is indeed the oil pump. Is the oil pump the same for a diesel and gas engine? Or are they different? I'm going to add the link to the pump that I want to buy but what throws me off is that it says diesel, and mine is a gas engine. http://www.amazon.com/98-06-Volkswagen-Beetle-Passat-Diesel/dp/B013H47BV6/ref=sr_1_1?ie=UTF8&qid=1461606927&sr=8-1&keywords=03+passat+1.8+oil+pump is that the right one?
Apr 25, 2016 at 3:53 AM
SATURNTECH9
  • 30,869 POSTS
If you click does this fit my car on Amazon it says it fits your car.As far as the diesel being the same I don't know if they are Rock auto dot com has your pump as well you can check it out on there as well.
Apr 25, 2016 at 6:08 AM
SATURNTECH9
  • 30,869 POSTS
I .Don't think they are the same I was looking at parts on rock auto dot com and they don't show a pump for sale for the diesel beetle but have one for your car so I would say there different.
Apr 25, 2016 at 6:13 AM
LUIS GUEVARA
  • 5 POSTS
Thanks this was very helpful
Apr 25, 2016 at 7:39 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome glad we couldn't help.
Apr 25, 2016 at 2:56 PM
