oil gauge registered very low oil pressure?
232,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TOM JONAS
  • 20 POSTS
I had low oil pressure when running my A/C on the interstate during very hot weather when i come to a stop light my check gauges light came on while in drive, but if i put in neutral the light went off. my original oil gauge registered very low oil pressure. i was using synthetic 5ww-30, i changed the oil to conventional 10w-30 with a high flow oil filter and i had a new heavy duty oil pump put in. i want to put a manual oil pressure gauge using copper tubing is there an oil plug on the side of the motor that i can hook up the mechanical oil pressure gauge to and find out my true oil pressure of my motor. I'm using 1/8 copper tubing this is the only time my oil pressure is really low. I also put a quart of Lucas oil treatment in the new oil and I put it in a new oil pressure sensor. Thanks
Sep 12, 2022 at 9:53 PM
  • 55,658 POSTS
Hi Tom,
To connect a manual gauge, you will need to remove the oil pressure sender and make a Tee arrangement for both the sender and the 1/8 copper tubing. A quick run to the hardware store should be sufficient for the job. Upload a picture of any problem you have so we can help.
Sep 13, 2022 at 2:01 AM
TOM JONAS
  • 20 POSTS
are you talking about the oil pressure sensor sir?
Sep 13, 2022 at 2:27 AM
TOM JONAS
  • 20 POSTS
Are there any 1/4-inch oil plugs on the outside of block somewhere on my motor and do u know what size the oil pressure is that screws into my motor? Thanks
Sep 13, 2022 at 2:30 AM
TOM JONAS
  • 20 POSTS
is that the only place to hook up my manual oil pressure oil line? Thanks
Sep 13, 2022 at 2:32 AM
TOM JONAS
  • 20 POSTS
Are the threads on the sensor metric or SAE? Thanks
Sep 13, 2022 at 2:40 AM
MIKE H R
  • 3,094 POSTS
Lower side of the engine block.
Locate the oil pressure sending unit; usually it is on the lower side of the engine block. Disconnect the wire from the sending unit and use an open-ended wrench to remove the sender. Using pliers can damage the unit. I would replace the new oil sending unit {the old one can go bad} along with putting in a manual gauge the kit comes with different sizes connections. You will need to get a t-connection, to one side for the sending unit and the other for a manual connection to an oil pressure gauge.
Sep 13, 2022 at 3:43 AM
TOM JONAS
  • 20 POSTS
Thanks.
Sep 13, 2022 at 4:08 AM
  • 55,658 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 14, 2022 at 4:27 AM
