The oil warning light should be on bright and steady when the engine is not running. If it's flickering there is a bad connection related to the sending unit circuit. Most often it is due to a bad contact inside the sending unit itself but there could be a poor contact in the electrical connector too. Disconnect the wire from the sending unit, then use a small jumper wire to ground the terminal. If the light is on bright and steady, replace the sending unit. If the light is still flickering there's a problem in the wiring.
SPONSORED LINKS
Monday, June 8th, 2020 AT 5:54 PM
(Merged)
