Oil pan
2000 SUBARU IMPREZA
245,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
ALEC END KING
  • 5 POSTS
Okay, so I used to do a pretty okay job at changing the oil. Someone once told me that I can change the oil just by taking out my filter letting it drain out and putting a new one on. Due to family issues I got distracted for months and I did not change my oil. One day at three in the morning I was on the freeway and I decided to race some guy and that is when I noticed that my car's tachometer started bouncing back and forth so I exited the freeway and my car shut off. Luckily there was a really cool guy with a tow truck at the gas station that I was at and he towed my car for free. He looked at it and he is not a mechanic, but he said he knows a bit. He saw that around my oil pan on the bolt it was leaking and even a little around my filter. So once I got home I waited to the morning and I took off the bolt that I had no idea existed and bang so much thick black oil started just coming out. And that is because before that I apparently "changed" my oil only putting roughly two quirts. Now the problem that happens is that my engine keeps shutting off it and it makes a loud kind of knocking noise. and I just want to know if you think it is my whole oil pan or just because I never properly changed my oil?
Mar 4, 2018 at 4:24 AM
WRENCHTECH
  • 20,761 POSTS
You just learned a hard lesson. You cannot drop the ball on oil changes. Times to start hunting for another engine.
Mar 4, 2018 at 5:12 AM
ALEC END KING
  • 5 POSTS
So you are saying there is no way I can fix it? Changing my oil pan and adding oil would not work? I had put some oil in and it started working. It was making knocking sounds then too and the noise has not changed.
Mar 4, 2018 at 5:18 AM
WRENCHTECH
  • 20,761 POSTS
No, the damage has been done now. I did not say it cannot be fixed, but another engine would be cheaper and easier.
Mar 4, 2018 at 5:20 AM
ALEC END KING
  • 5 POSTS
Alright, thank you for the help.
Mar 4, 2018 at 5:21 AM
WRENCHTECH
  • 20,761 POSTS
You are welcome.
Mar 4, 2018 at 5:26 AM
ALEC END KING
  • 5 POSTS
So what do you think it is? I have a friend that is a mechanic and says he can help with it. Is it the parts that are expensive or is it the labor that would be expensive?
Mar 4, 2018 at 7:06 AM
WRENCHTECH
  • 20,761 POSTS
Rebuilding it would be lots of everything. Lots of parts, lots of labor and lots of sublet machine shop labor. You will be rebuilding the engine if you repair it and unless he is experienced in machine work and rebuilding engines, you are better off just finding a good used engine.
Mar 4, 2018 at 7:10 AM
ALEC END KING
  • 5 POSTS
He knows how to rebuild engines but I am not sure on the machine work. I will just go with getting a new engine. Oh well, I was going to swap it anyways I just did not think it would be this soon.
Mar 4, 2018 at 7:13 AM
