Oil light will not start
120,000 MILES • 2.5L • V6 • AUTOMATIC
JOHN MATHEW
Old battery have to get jumps often.
Sitting parked in idle and the car was fine but then began to shake and as it shook the oil light flickered and then shook rougher and turned off and the oil light came on solid.
Put gas in, not that.
Hooked to friends Prius did not start.
Cranks but does not fire.
There is a coolant leak coming out of the little screw cap right of the engine, and was barely visible but still present white smoke from tail but it went away.
Car cranks quickly but does not fire, all lights work, convertible top works.
Used one, nothing no check engine light.
Plenty of fuel.
The coolant is septic and probably needs changing, the oil is dirty and sticking my finger into the fill hole there is a lot of grudge and dirt on my finger.
Apr 26, 2021 at 1:17 PM
JOHN MATHEW
I meant used an obd sensor, but no check engine light.
Apr 26, 2021 at 1:29 PM
The white smoke and cranks quickly has me worried and I think we have a head gasket issue.
Can you check the oil and make sure it doesn't have coolant in it?
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Also, we can test the head gasket using this guide:
Let's run through this info and go from there. Thanks
Apr 27, 2021 at 1:39 PM
